ALMOST READY TO SHOOT RANGER
Old Jan 30, 2006 | 02:46 PM
grizzly's Avatar
Default ALMOST READY TO SHOOT RANGER
I HAVE A 94 RANGER 2.2 L HAS 118 THOUSAND MILIES ON IT BEEN A GREAT TRUCK, TILL ABOUT 6 MONTHS AGO IT WOULD NOT START JUST TURN OVER SHOT SOME STARTING FLUID IN IT AND POPED RIGHT OFF RAN GOOD TILL ABOUT A WEEK AGO AND ITS DOING IT AGAIN, YESTERDAY I HAD TO USE STARTING FLUID 6 DIFFRENT TIMES. I HAVE REPLACED THE FUEL PRESSURE REGULATOR AND THE IGNIGHTION SWITCH. CAN THE FUEL PUMP WORK INTERMITEDATLY? NOT SURE WHAT TO DO.
Old Jan 30, 2006 | 05:11 PM
techmanbd's Avatar
Default RE: ALMOST READY TO SHOOT RANGER
Could be, Have you replaced the Fuel Filter, cleaned the injectors?
Old Jan 30, 2006 | 05:18 PM
grizzly's Avatar
YES I CHANGED FUEL FILTER, I RAN SOME SEA FOAM IN THE GAS FOR THE INJECTORS, CAN A FUEL PUMP WORK INTERMINTALY LIKE THAT?
Old Jan 30, 2006 | 08:26 PM
Ramrod48's Avatar
at this point anything's a guess . you need to put a pressure gauge on the fuel rail an see what kinda fuel pressure your getting . It could be electrical, faulty relay , faulty interia switch, bad ground to the pump, faulty fuel pump ,in tank , or the high pressue one , just guessing you could spend a ton of money
craze173
Nov 20, 2012 05:34 AM
cat5656
Jun 29, 2011 01:44 PM
Dwildman
Nov 13, 2007 08:17 AM
tsi18psi
Oct 8, 2007 12:11 AM
Frankenstein Ford
Nov 3, 2006 11:20 PM
