Am I getting ripped off?
Old Sep 30, 2007 | 02:29 PM
edpdx's Avatar
Default Am I getting ripped off?
My 4.6 Crown vic is in the dealer shop. I got a call that the #4 cylinder had some kinda prob. That the bottom end was tested and the prob was in the #4- could be a valve or busted spring. Dealer quoted me $1900. to pull the head and determine the problem (plus mach shop charges). I ok'd this since the Serv Mgr was adamant that the prob was definitely in the #4.
Next call I get is that the mechanic said the valve had scratched a lobe on the OH cam and that I would need a new cyl head. I have worked on my cars since 1975- no OHCs but I figured a cam is a cam and that a damaged cam would be replaced, maybe the bearings as well. I looked in the Ford manual and the manual outines the procede for R&R of a cam. Nowhere does it say replace the entire cyl head and valve train if there is damage to the lobe. The Serv mgr said I need a new head. He said $730 gor a dealer ford head. I authorized it. But I have been very suspicious.
Next call the Serv mgr tells me that the head is now building too much pressure and that a ring job is requires; but I may just need a NEW ENGINE.
The car was running tip top before it started pinging under load- I thought it was a dirty IAC OR EGR maybe. Is tehre any reason I need to have a new engine. At what point should I have become suspicious (assuming you think I should be)?
And what should I do now? The dealer says $2100. to pick up my car without any improvement over when I brought it in- no new engine of course.
HELP, I mean help!
edpdx
Old Sep 30, 2007 | 05:04 PM
tsi18psi's Avatar
Default RE: Am I getting ripped off?
If the car was running fine, besides the noise.
I would say maybe a new head at most.\
If the lobes on your cam are damaged you would notice it.
P.S If they put a new head on and its not functioning like it should that is thier fault not yours.They are responible to fix it.
Old Sep 30, 2007 | 05:38 PM
david paul's Avatar
sounds like you are getting a ROYAL F _ _ _ _ _ _
fight them all you can and report to better business bureau tell tem you will give them all the bad publicity you can
90tonkatoy250
Jul 7, 2009 08:56 PM
TerryP
Oct 4, 2008 09:42 PM
hiltoneous
Mar 26, 2008 02:30 PM
grey7399
Dec 16, 2006 12:29 AM
redskins13
Sep 9, 2006 06:07 PM
