A/C Freezing up
I have a 2007 Taurus and for a few weeks now if I run the air on max and the fan on low the fan stops blowing air through the vents. If I turn the fan to high it sounds like there is blockage in the flow path. I guess it is freezing up. If there is anyone that can help me please let me know what to do. I had the condensor replaced in February but it just started freezing up in the last month or so. Thanks in advance for your help. Henry
You may have a bad evaporator temperature monitoring thermostat. The thermostat monitors the temperature of the evaporator fins and controls system operation within set limits. The thermostat usually cycles the system between a minimum of 2°C [or 35.6°F] and a maximum of 8°C [or 46.4°F] to maintain the evaporator at the required temperature. If this thermostat is bad, the evaporator will ice up causing the lack of air flow.
I cannot find a low pressure cut out switch for this car. Could it be called something else. Also does removing this switch cause the freon to be released or is it a sealed system. The only switches listed for this car arethe a/c clutch cycling switch. If this is it I can probably get it installed myself as long as all the freon won't escape.
