camshaft position (CMP) sensor ticking
For the 12Valve engine, There are two parts to the sensor, the pickup part can be replaced by just removing the two screws and installing a new one, however, if the pickup has come apart and chewed up the rotating assembly that is installed in what use to be the distributor(I think it referred to as the stator assembly but don't quote me on that) you will need the ford special alignment tool to install another one. It is the sensor that is ticking and not a noisy injector? The sound of the injectors will change when you unplug the sensor as the PCM will switch to bank firing the injectors (fires in 2 groups of 3 inj.) because if no longer has the cam reference position to syncronize the injectors for multiport firing.
skaneverdies
Dec 1, 2010 02:24 PM
justin1980
May 30, 2005 10:28 AM
