check engine light and missing
Old Aug 23, 2006 | 10:54 PM
crazyman's Avatar
Default check engine light and missing
I got a 1999 ford expedition and these are my issues: filled up with gas drove about 200 miles and expedition started to miss very bad and check engine light was flashing. Started with new spark plugs, didn't fix. when I had it scanned no codes came up except the on for the check engine light, but the left bank down streamO2 censor was not as responsive as the others so I replaced it. I have checked the injectors and the COP's (coil over plug) they where good .The fuel pressure is 35 psi, the fuel pressure regulator is making a differance when dissconected. The tank was drained to within about 1/16 of a tank then filled with 91 octaine and lucas injector cleaner and fuel conditioners was added.
If anyone can help
Thanks: Crazyman
Old Aug 24, 2006 | 10:38 AM
Bullitt94's Avatar
Default RE: check engine light and missing
After replacing all of that, did you try to clear the codes? Sometimes clearing codes helps, and if it doesn't work it may then give you a new code to work from.
allensimpson
Jan 10, 2008 09:40 PM
crazyman
Sep 30, 2006 01:37 AM
crazyman
Aug 24, 2006 10:58 AM
crazyman
Aug 24, 2006 10:38 AM
shoreline
Oct 30, 2005 10:14 PM
