| rottn30 |
Nov 2, 2007 08:31 PM |
RE: Cruise control troubleshooting
I bought a 94 F150 back in March the crusie didnt work. My brother in law who use to work for Ford took apart the control box. The gears were froze up, so hecleaned it and sprayed lube on the gears put it back together it worked fine. I dont use it a lot but the next time I did it wouldnt work again. I took it apart and it was froze up again I cleanened and re lubed the bearings at the motor on the inside. Then cafully poped the cap off the outside bearing cover ( carefull has a sping between bearing and cap) it had a slight surface rust on it. I cleaned it then put a light lube on it and on the cover to seal out moister pressed the cap back on and pinched it back tight with a pair of pliers ( it is like a bottle cap it has to be recapped to keep it on). Since then it has worked every time I needed it.
