Diesel Dilemma - can you HELP ?!
Old Feb 27, 2011 | 04:05 PM
JosephR's Avatar
Default Diesel Dilemma - can you HELP ?!
Hi there
I am going to buy a MKII Fiesta - probably a 1.1L petrol from 1987. The 1.6 diesel version is quite rare in Britain, so I was wondering if I can take the 1600cc diesel from a donor car which I have found and replace the 1100cc petrol unit in a Fiesta which is in much better condition. Do you know if this is mechanically possible ? And how much work is involved if so ? I wouldn't undertake the work myself, probably asking a local garage to do the job. It sounds a bit of an odd question as most drivers prefer the petrol engine, though I'm a big diesel fan and keen to organise the above. Many thanks guys in anticipation. Joe.
Old Feb 28, 2011 | 07:38 AM
Use Common Sense's Avatar
Since the second generation Fiesta Mark II (1983–1989) came with the 1.6L diesel engine, it should be an easy swap since you would have a complete donor car.
Engine, transmission, wiring, computer, fuel pump and such.
Old Feb 28, 2011 | 04:17 PM
JosephR's Avatar
Thanks for your help. The couple of things that spring to mind are:
1) wheels - the petrol engined mk2 fiesta seem to have smaller wheels, would I therefore need to change these to ?
2) fuel tank - are there any alterations to be made here ?
3) exhaust - do you think this could remain as it is ?
Many thanks readers, in anticipation
Joe
Old Mar 1, 2011 | 06:28 AM
1. The size of the tires should be OK. They may be smaller based on the package that was ordered for the vehicle. The gasser may have been ordered with a larger tire, or were replaced sometime during its life.
2. The fuel tank should be the same. Only difference that I can think of would be the filler neck may be changed. Diesel nozzles are normally larger, thus needs a larger filler opening.
3. The exhaust may be the same except for where it connects to the engine. I don't know what type of pollution control devises were required in your area for the 1987 year. If anything, if the gasser has a catalytic converter, it would most likely need removed for the diesel installation.
loseraic
Jul 22, 2018 04:33 PM
JSbethlehem
Sep 23, 2014 05:58 AM
LiveIron
Mar 1, 2010 07:13 PM
daschae
Jun 25, 2008 11:35 AM
