distributor/voltage problem
Hi, All its been awhile..Here's my problem I have a 1976 Ford f 600 dump with a 360 v-8 that wont start.. when I moved it started and ran normal just finish putting new points and condenser cap wire's etc...went to start it 2 week later and now it wont start.. I have a voltage issue Turn the key on and check volt @ the coil have only 6 volts on the battery side..0 volt on the distributor side ..now if I pull the distributor side off the coil ..my 12 volts is there..when I plug it back in on the distributor side back to 0 volt there and 6 volts on the battery side...Now with that said I..replace the coil and the voltage and voltage regulator condenser and also the distributor and it still the same...NEED YOUR HELP ... if you have any idea please let me know...Thank you for your time
Do you recall what gap you set the contact points to when the rubbing block of the points was on the high point of the dist cam? Should be about .015 in. About the thickness of a matchbook cover. Also did you replace the cap one wire at a time or placed the wires in any tower. Important to go in firing order and correct dist rotation. (clockwise/counter clockwise) We 'll take things one at a time. I don't know how much you are familiar with, so help me out and don't spare the details, thanks.
(Post 112571)
There is nothing wrong , it is supposed to do that.
What is critical is the point gap, make sure you set that correctly. You don't need a wiring diagram, because it is pretty simple Again just make sure to set the point gap as suggested earlier. Did you remove the dist or move it from it's earlier position? That will affect timing and if you didn't move it, best not to until you get it running. When everything was set correctly , they ran pretty good. |
(Post 112582)
Glad you got it running, thanks for the update.
