dtc code
hi.. i have ford ecosport diesel . it has only pcm . it did not have abs/rcm/srs ect. but its pcm has 2 codes b1206 and p2508 and car starts but only for 10 to 20 sec. help me plz plz plz
Because all years are not the same, what year is your vehicle and what if anything have you checked so far ?
dtc
its 2014 and i connects only a scantool its launch 129 primium i have see all ground connections in engine compartment and sensors and connectors
There may be a fuel supply problem.
Can you tell us when the problem started and what were you doing with the vehicle when the problem started. Could the vehicle be out of fuel? Tap the bottom of the fuel tank to see if it sounds like it is empty unless you just put fuel in it. |
