dtc code
Old Jun 23, 2018 | 07:56 PM
Vikas Kumar's Avatar
Default dtc code
hi.. i have ford ecosport diesel . it has only pcm . it did not have abs/rcm/srs ect. but its pcm has 2 codes b1206 and p2508 and car starts but only for 10 to 20 sec. help me plz plz plz
Old Jun 24, 2018 | 09:41 AM
Because all years are not the same, what year is your vehicle and what if anything have you checked so far ?
Old Jun 24, 2018 | 12:18 PM
Default dtc
its 2014 and i connects only a scantool its launch 129 primium i have see all ground connections in engine compartment and sensors and connectors
Old Jun 24, 2018 | 04:36 PM
There may be a fuel supply problem.
Can you tell us when the problem started and what were you doing with the vehicle when the problem started.
Could the vehicle be out of fuel?
Tap the bottom of the fuel tank to see if it sounds like it is empty unless you just put fuel in it.
61 2DOR
Apr 11, 2023 09:46 AM
macdunc
Dec 10, 2016 02:33 PM
econo350
Jul 12, 2012 08:55 PM
mathew
Feb 25, 2012 05:51 PM
PASBON
Oct 29, 2009 08:57 PM
