Engine misfire.
Old Dec 31, 2005 | 01:34 PM
sunderco's Avatar
Default Engine misfire.
I own a 1998 F-150 with a 4.2 engine, I have a misfire on cyl.5 & 6 , and lean mix code. but there is fuel coming out of the exhuast pipe.? I replaced the coil pack . And i dont know where to go from here. Please help. Thank you
Old Dec 31, 2005 | 09:07 PM
mstngmach's Avatar
Default RE: Engine misfire.
I had a similar issue with my 94 Thunderbird. I checked coil packs, plugs, plug wires, injectors, potential vacuum leaks, and compression and found no problems. I finally replaced the computer and it fixed the problem. Apparently the injectors were not firing correctly.
mardyel
Sep 23, 2025 05:41 PM
ynwia
May 6, 2010 03:49 AM
disbanded
May 12, 2008 08:03 PM
robbyb55
Jun 24, 2007 11:31 AM
ddybrown
Mar 31, 2007 02:40 AM
