fairmont speedo not working
Old Feb 26, 2010 | 03:08 PM
fairmonster's Avatar
Default fairmont speedo not working
So I'm out driving, speedo works fine, stop off and radio shack, fire it back up and speedo doesn't work. I have a 79 straight six fairmont (not futura). Is there a fuse that specifically governs the speedo? Is this a common problem? Luckily I had a gps in the car so I could keep track of my speed.
Thanks.
Old Feb 27, 2010 | 05:50 AM
david paul's Avatar
that would be speedo or the speedo cable they weren't elect. back then
Old Feb 27, 2010 | 01:57 PM
heerdez's Avatar
verify that the cable is not loose its conection
Old Feb 28, 2010 | 11:16 AM
Where does the cable connect to the transmission? I am having a hell of a time getting to where it connects to the instrument cluster... damn this is a pain in the ***.
Old Mar 1, 2010 | 04:51 AM
heerdez's Avatar
to tranny tail ad in the rear of the speedometer those are the only 2 places it connects to
Old Mar 1, 2010 | 01:42 PM
digital_diversion's Avatar
speedo cable attaches on the extension housing of the tranny....should be a lock bolt to hold the speedo assembly into the extension housing.
pull it out and check to make sure plastic gear is not "apple cored" (worn out)
you might need to replace the rubber o-ring around the speedo housing...or just use some high temp silicone...
you can spin the gear by hand once you have it out and have someone watch up in front to make sure it works....
Old Mar 2, 2010 | 07:44 AM
david paul's Avatar
good answer
Old Mar 3, 2010 | 07:11 AM
heerdez's Avatar
have u resolve your problem yet
Old Mar 3, 2010 | 10:58 AM
Not yet, its been cold and rainy lately, I'm gonna tear into her today. Thanks for the help guys, I'll let you know if I have any issues.
Old Mar 4, 2010 | 08:35 AM
heerdez's Avatar
keep me posted and ill ask my friend see if anything else is the problem ,,nice and warm out here 91 degrees here
