Flexplate/flywheel interchangeablity
Old Jan 20, 2021 | 09:43 PM
RacingRoger's Avatar
Default Flexplate/flywheel interchangeablity
I have a 5.0 H.O. with a clutch/flywheel (50 oz imbalance). I want to buy a junkyard Explorer 5.0, and it looks like this one will have a flexplate for an automatic transmission (also 50 oz imbalance).
If I swap out the flexplate for the flywheel, is it reasonable to expect the rotating assembly to be balanced? Would I need to swap the harmonic balancer over also? Or will I have to gut the entire rotating assembly to have it all balanced?
Thanks in advance!!!
Old Jan 23, 2021 | 08:19 PM
Nobody has tried swapping flexplates and flywheels?
Old Apr 24, 2021 | 07:29 AM
Virginia250's Avatar
New here, but my Windsor experience is that you will be fine. The engines are balanced from the harmonic balancer to the flywheel/flexplate.
hunterhartter
Sep 20, 2012 09:18 PM
Racerat100
Aug 30, 2009 02:14 PM
CocoChanels
Jul 21, 2009 11:49 AM
tdf
Jun 5, 2007 04:01 PM
smokeyandthebandit05
Feb 7, 2006 11:52 PM
