Front Fuel Tank Won't Feed
Old May 12, 2007 | 12:21 PM
dadstruck's Avatar
Default Front Fuel Tank Won't Feed
I have an 89 F150 6 cylinder. I drove to the gas station and the front fuel tank was working fine. I filled the front tank with gas leaving the rear tank nearly empty. Then after running on the front tank for about two minutes the engine cut off. I switched to the rear tank and the engine restarted. Apparently fuel flow was restored. I repeatedly switched to the front tank form the rear and the engine stalled every time after about two minutes. The fuel guage changes to indicate the respective fuel amounts when I switch tanks. Did the front tank pump just coincidentally die after refueling or could it be something else?
Old May 15, 2007 | 03:23 AM
Use Common Sense's Avatar
Default RE: Front Fuel Tank Won't Feed
It could be your selector valve going bad. The FORD selector valve uses a +12vdcmotor toswitch to the rear tank with a SPRING return to normal for the front tank. It could be that the spring is getting week. If it is in fact failing, I would replace the selector valve with a POLLAK valve. These use +12 vdc motors in both direction for a positive switch.
greyheadedguy
Sep 30, 2012 11:14 PM
THEGOOSE
Feb 22, 2009 10:45 PM
jsimpson
Jan 25, 2009 12:26 PM
Sasquatch
Jul 25, 2006 07:17 PM
butters417
Mar 22, 2005 06:54 PM
