Won't pick up fuel when at 1/4 of a tank
Old Sep 24, 2012 | 11:07 PM
greyheadedguy's Avatar
Default Won't pick up fuel when at 1/4 of a tank
I have a 98 F-150 XLT standard cab step bed. When my fuel gauge hits 1/4 tank the engine stalls out and dies. Add gas and it runs fine. I tapped on the fuel tank and it seems to have about 1/4 tank of fuel. I filled the truck with it being around 1/4 tank and it took 16 gallons of gas. Should be a 25 gallon tank according to my manual. Any ideas why it won't pick up fuel once it gets to 1/4 tank?
Thanks for the help in advance,
grey
Old Sep 25, 2012 | 09:35 PM
greasemark's Avatar
One thought that jumps to mind is something wrong with the fuel sender; many different body styles use fuel pumps that are similar, but not identical. It's possible that a shorter sender is installed, or possibly the pump is just having internal problems.
Old Sep 26, 2012 | 12:35 AM
I inherited the truck from my Dad. I drove it across country from Cincinnati, to bring it home and everything worked fine. Only after sitting a spell did problem pop up. Here is a dumb question, if someone put water in the before I put a locking gas cap on it, could that have caused the problem? I'm not saying it did happen but I have had some strange problems with a former neighbor and wonder if it could be a possibility.
Old Sep 30, 2012 | 04:20 PM
85_ranger's Avatar
if you can try checking and see if there is a leak in th pump some where ive had this same problem before and it was the hose that connected the pump to the outlet had rotted away is a simple fix with some good fuel like and a couple hose clamps if that may be the issue
Old Sep 30, 2012 | 06:34 PM
Hose problems at the top of the tank a common problem, worth looking into.
Old Sep 30, 2012 | 11:14 PM
85_ranger's Avatar
yeah ford didnt usethe greatest fuel line on there fuel pumps back then..
THEGOOSE
Feb 22, 2009 10:45 PM
effer
Nov 28, 2007 06:48 PM
dadstruck
May 15, 2007 03:23 AM
Alfonso
Oct 11, 2006 04:43 PM
xc_ute
Jan 2, 2005 05:44 PM
