fuse diagram
Can someone tell me what fuse go to fuel pump? Can't find a diagram any where. Thanks joey!
Just google , Ford owner manuals
(Post 103631)
Try this site and go to the owners manual for your specific vehicle.
www.fleetford.com It should show or explain which fuse is for the fuel pump. Go to the fuse relay section of the manual. |
Sorry about the site suggested ,
Just type in Ford owner manuals. |
(Post 103649)
By this time it appears you are having a fuel pump power problem. If this is so, did you check if the inertia switch has been tripped? It is located behind the top of the passenger side kick panel. If this isn't the problem, let us know, OK ?
(Post 103658)
If you haven't fixed the problem yet, Do have power available at the inertia switch when cranking over the engine?
There are two fuel pumps on that vehicle,one low press pump in the tank and a hi press pump on the rail. Does your vehicle have one tank or two? |
(Post 103796)
Thanks for the update !
