fuse diagram
Old Aug 23, 2017 | 12:42 PM
joey7478's Avatar
Default fuse diagram
Can someone tell me what fuse go to fuel pump? Can't find a diagram any where. Thanks joey!
Old Aug 23, 2017 | 05:13 PM
Just google , Ford owner manuals
Old Aug 24, 2017 | 04:55 PM
joey7478's Avatar
Try this site and go to the owners manual for your specific vehicle.
www.fleetford.com
It should show or explain which fuse is for the fuel pump. Go to the fuse relay section of the manual.
that site doesn't work
Old Aug 25, 2017 | 05:55 AM
Sorry about the site suggested ,
Just type in Ford owner manuals.
Old Aug 25, 2017 | 10:49 AM
joey7478's Avatar
Iv'e looked at all fuse diagram on these sites and it doesn't show a fuel pump fuse.does a 1990 van have a fuse for fuel pump?
Old Aug 25, 2017 | 03:43 PM
By this time it appears you are having a fuel pump power problem. If this is so, did you check if the inertia switch has been tripped? It is located behind the top of the passenger side kick panel. If this isn't the problem, let us know, OK ?
Old Aug 30, 2017 | 05:04 PM
joey7478's Avatar
OK I checked the inertia switch and even jumped the wires and than ran a hot wire to pump on frame and it would run. the pump won't run otherwise. the only other thing I can think of is if my fuel gauge is wrong and I'm out of gas. Thanks joey!
Old Aug 31, 2017 | 11:14 AM
If you haven't fixed the problem yet, Do have power available at the inertia switch when cranking over the engine?
There are two fuel pumps on that vehicle,one low press pump in the tank and a hi press pump on the rail. Does your vehicle have one tank or two?
Old Sep 1, 2017 | 11:06 AM
joey7478's Avatar
Smile
I have it fixed after trying three relays it is pumping gas. Thanks for all the help joey!
Old Sep 1, 2017 | 12:12 PM
Thanks for the update !
stptak
Apr 14, 2013 02:48 PM
cardinal33
Jan 15, 2008 08:34 PM
renea_5441
Oct 21, 2007 07:24 PM
AndrewMacks4.0
Jul 13, 2006 12:44 PM
biebrich73
Jun 30, 2005 12:52 AM
