HELP>>Tension Pulley<<HELP
Old May 12, 2007 | 05:48 PM
bones185's Avatar
Default HELP>>Tension Pulley<<HELP
Replacing a drive belt on my old 94 mazda B2300 (ford ranger).
The tension pulley obviously swivals to the left to release tension, but the one bolt on the front is a Torx head, with just enough room for a ratchet w/ the torx adapter. (wich i don't have)
isloosening thatbolthow you turn that pully?ifnot, thenhow then??? if so, then isthere any other way besides going out and buying yet another tool to fix the darn thing??
Old May 15, 2007 | 03:33 AM
Use Common Sense's Avatar
Default RE: HELP>>Tension Pulley<<HELP
Ypu don't actually loosed the bolt up. By placing the rachet w/torx bit in it, you pull the rachet like you're going to loosen the bolt up. However, what happens is you actuall compress the tension spring allowing your to remove/install the belt. Then you just release the tension and let the tensioner fall back into place.
nickt892003
Nov 20, 2022 05:23 PM
searchlight4759
Jul 10, 2012 08:23 PM
Amos Harper
Nov 10, 2010 08:53 PM
mpgpatfan
Jul 18, 2008 10:41 AM
Fordguy212
Nov 13, 2007 01:13 AM
