help with timing specs/procedure
Old Jan 13, 2006 | 11:15 AM
colt2245p's Avatar
Default help with timing specs/procedure
well i am the proud new papa of a 90 E150 van with 302efi and aod trans i would like to check timing and would like help with specs and procedure dont you have to short a terminal out somewhere? also what kind of fuel milelage should i expect driving it like an old lady thanks
Old Jan 13, 2006 | 08:43 PM
way2old's Avatar
Default RE: help with timing specs/procedure
There is a spout connector around the distributor. It is a little plug that connects 2 wires together. The timing should be set to 10 degrees BTDC. Mileage will vary due to the state of tune, weight in vehicle, tires on vehicle and air in the tires. Average should be 10-12 and 15-18
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
1406j
Oct 8, 2008 08:54 PM
Nextweek
Jul 4, 2008 02:21 PM
Qaiphyx
Apr 4, 2008 11:59 AM
