Hole in engine block
Old Aug 5, 2020 | 02:30 PM
lariatf150's Avatar
Default Hole in engine block
What can cause a hole in the lower part of the engine block above the oil pan? I drive a 2016 f150 lariat 5.0L V8.
Old Aug 5, 2020 | 03:13 PM
Your driving it? Any knocking, noises prior? Generally the big contributor is a connecting rod let go. If the base engine, rotating assembly is coming apart, take an oil sample at the pan plug and see what comes out. If a rod, there will lots of metal shavings, metallic debris..
Old Aug 5, 2020 | 05:29 PM
lariatf150's Avatar
this was when I started my truck and heard a banging noise coming from the engine. Oil was on the ground with small metal pieces on the ground.
Old Aug 5, 2020 | 07:33 PM
Yeah, sounds like a piston connecting rod let go.
Old Aug 5, 2020 | 07:41 PM
lariatf150's Avatar
they said a inspector has to come out from the warranty company and I don’t know why.
Old Aug 5, 2020 | 08:41 PM
scott.butler4's Avatar
Inspection of vehicle is standard procedure most any non OEM warranty claims and some OEM warranty claims.
Wouldnt you want to see the hole in your engine before paying a dealer probably over 3 or 4 grand for a new engine, Labor rate for a 5.0L F150 is like 18 or 20 hours.
Old Aug 6, 2020 | 07:38 AM
lariatf150's Avatar
yes they said it would be like 20 hours of labor and that it would be around $11,000
Old Aug 6, 2020 | 08:13 AM
**** for that price you are getting a entire brand new engine, sometimes they get cheaper used engine or only get a short block and reuse the heads to keep cost down.
Old Aug 6, 2020 | 10:12 AM
lariatf150's Avatar
they said it’s a rebuild everything brand new inside But the engine block is not new.
Old Aug 7, 2020 | 07:32 AM
raski's Avatar
Probably a short block and they transfer everything else from your original.
