How do I???????
Old Jul 26, 2007 | 08:45 PM
beeleeva's Avatar
Default How do I???????
I just bought a 2000 Ford Explorer with a keyless pad on the driver door. How do I get the code and learn about resetting the code?
Old Jul 29, 2007 | 02:37 PM
dgordon's Avatar
Default RE: How do I???????
In the rear of the truck on the drivers side remove the panel below the side window.There will be a square metal box you may need a flash light and mirror to see the numbers on the box.If the code has not been reprogrammed by a dealer the #'s on the box will be your code,if the code has been changed you will have to take the truck to your local dealer to have it retreived.
