No Communacation Snap-on scanner Probe
Old Mar 15, 2008 | 12:10 PM
FryingRines's Avatar
Default No Communacation Snap-on scanner Probe
Hi, I'm working on a 93 probe,it has control of the lock-up switch in park,ie:O/D on-off but in gear or driving it flashes,[/align] My mt-2500 snap-on scanner won't comm., and show's no codes I'm looking for a schematic as this may have a wire problem or bad solenoid,it also has an harsh up shift problem.[/align]
Any help here would be most appreciative
[/align] Ben[/align]
Old Mar 15, 2008 | 10:19 PM
grease_monkey1965's Avatar
Default RE: No Communacation Snap-on scanner Probe
your fuse might be blown,on my ranger the connector runs on the same fuse as the cig lighter,if the fuses are good you will want to check the pins one of them should show 12v with key on,if not you might have a bad ground to computer,electrical is a pain
motorman499
Jan 23, 2011 03:23 AM
judgebc
Sep 28, 2009 11:26 AM
mbeards
Feb 25, 2009 11:13 PM
anlufu
Feb 19, 2007 11:44 AM
davidsca
Jun 25, 2006 01:36 PM
