Oil in Air Intake?
Old Feb 2, 2010 | 02:36 PM
Vlaj's Avatar
Default Oil in Air Intake?
1999 Ford Contour, ~ 160.000 miles
DOHC, 2.0L, VIN CODE 3
Before 2 weeks ago, I never had a leak under the car. Every oil change, dry undercarriage.
2 weeks ago, I replaced my valve cover gasket since there was some oil leaking there.
Then last week I changed my air filter and noticed oil in the Air Intake. Subsequently, oil started dripping under the car. (rear main seal>) Coincidence? Something with the pressure after replacing the valve cover gasket?
Been using 5x30 Ford semi-synthetic motor oil and changed last week 5x30 Castrol GTX high performace oil and odded the Bar's Leak.
Suggestions please what to check for?
Thanks
Old Feb 3, 2010 | 10:44 AM
Use Common Sense's Avatar
Here's a few items to check.
1. A faulty PCV valve.
2. A plugged fresh air intake valve for the PCV valce system.
3. Worn piston rings (Do a warm engine compression test).
Old Feb 3, 2010 | 08:48 PM
Vlaj's Avatar
Where do I locate the fresh air intake valve for the PCV valve system?
jcasaccio
Oct 7, 2018 08:02 AM
tcaswell0282
Jan 16, 2009 10:40 PM
proud2bfordpoor
Apr 1, 2006 01:41 PM
elbert
Nov 19, 2005 01:33 AM
dngrrngr93
Aug 9, 2005 05:17 PM
