power window motor
I just installed a new window regulator on a '95 Crown Vic. The old one was shot. Now, when my window closes as it nears the top, the window slows down. I swapped the motor with another one on the car, but I got the same results. It appears that there is too much friction in the window channel. The new window regulator works smoothly.
Does anybody have any suggestions?
Thanks,
chris
Thanks,
chris
try some silicon lubricant spray in the tracks for the window especially near the top of the tracks. also check the operation with the cover off the door so you can see if something is going into a bind and slowing things down. in my 88 Stang there is a central rod that the window rides on and this may be bent or out of alignment, just a thought, don't know if the newer ones are similar or not.
