radio removal on a 2005 expedition
my 6 disk changer just stopped working the other day. it will say its loading, or ejectiong or changing disks, but there is nothing happening. the radio still works on it. SOOOOO, i need to remove the unit but i cant find how to remove the front dashboard molding/cover to get at the radio. how is that removed?
RE: radio removal on a 2005 expedition
SOME MODELS HAVE A RADIO REMOVIL TOOL THAT U PLACE IN TWO LITTLE HOLES ON EACH SIDE OFF RADIO
No tool needed. At least not untilI remove the molding, butI think its held in with some screws anyway. LUCKLY.... it magically started working again....so the removal has been put on hold now until it decides to crap out on me again. thanks though. If anyone still knows how to remove trim, let me know just in case.
hey supafly,you do need removal tools to take out the radio.they are u shaped and go into the loittle holes on the face of the radio.as far as the problem you are having withh the radio is as follows:make sure you have an original recorded cd,(cd that isnt recorded by you),make sure all wires are firmly in place,but it definitly sounds like the gyro in the cd player is going out,(common problem with ford cd player radios),count on getting a rebuilt one for your truck.........joey
Audio unit is screw attached to the dash supportbehind the instrument finish panel.. No release tool needed.. Depending on floor shift, or column shift, the instrument finish panel removal is different..
