radio removal on a 2005 expedition
Old Oct 27, 2007 | 01:53 PM
supafly223's Avatar
Default radio removal on a 2005 expedition
my 6 disk changer just stopped working the other day. it will say its loading, or ejectiong or changing disks, but there is nothing happening. the radio still works on it. SOOOOO, i need to remove the unit but i cant find how to remove the front dashboard molding/cover to get at the radio. how is that removed?
Old Oct 27, 2007 | 02:03 PM
david paul's Avatar
Default RE: radio removal on a 2005 expedition
SOME MODELS HAVE A RADIO REMOVIL TOOL THAT U PLACE IN TWO LITTLE HOLES ON EACH SIDE OFF RADIO
Old Oct 28, 2007 | 11:49 AM
supafly223's Avatar
No tool needed. At least not untilI remove the molding, butI think its held in with some screws anyway. LUCKLY.... it magically started working again....so the removal has been put on hold now until it decides to crap out on me again. thanks though. If anyone still knows how to remove trim, let me know just in case.
Old Oct 28, 2007 | 08:31 PM
liljoey007's Avatar
hey supafly,you do need removal tools to take out the radio.they are u shaped and go into the loittle holes on the face of the radio.as far as the problem you are having withh the radio is as follows:make sure you have an original recorded cd,(cd that isnt recorded by you),make sure all wires are firmly in place,but it definitly sounds like the gyro in the cd player is going out,(common problem with ford cd player radios),count on getting a rebuilt one for your truck.........joey
Old Oct 28, 2007 | 09:51 PM
Audio unit is screw attached to the dash supportbehind the instrument finish panel.. No release tool needed.. Depending on floor shift, or column shift, the instrument finish panel removal is different..
supafly223
Jul 18, 2012 11:56 AM
Ratpack
Mar 11, 2008 02:56 PM
howard
Jun 8, 2007 09:45 PM
Jagee
Aug 18, 2006 05:45 PM
gotspeed13
Sep 29, 2005 04:12 AM
