still no signal lights
Old Mar 20, 2006 | 11:02 PM
cat's Avatar
cat
Default still no signal lights
even put a new relay switch on,and still no signal lights,could it be a blown fuse?
Old Mar 28, 2006 | 03:43 AM
sean08's Avatar
Default RE: still no signal lights
yes, it could be that you have a blown fuse. if it's a blown fuse, you can easily change and install a new one. guess you will have to replace your signal lights. you can have your replacement bought from here: Lights. sometimes the signal lights won't work because of some problem on the ground circuit. it may also be a good idea to clean the connections.
willy j
Oct 9, 2025 03:02 PM
jdm
May 27, 2007 08:08 PM
sunshinei95
Apr 9, 2007 03:24 PM
raquelw11
Dec 12, 2006 11:49 PM
cat
Mar 8, 2006 04:26 AM
