Taurus not getting spark
Old Mar 8, 2010 | 08:19 AM
tjfohrenkam's Avatar
Default Taurus not getting spark
Strangest thing. Have a 95 Taurus that has been sitting for about 5 months. Started it on a regular basis just not driven. Decided to pull it out to drive again. Started up great, put on new front brakes and replaced thermostat. Started up great again after repairs. Came out about 20 minutes later, car will not start again. Replaced several things including coil and ignition control modules. Car turns over no spark. Suggestions ??
Old Mar 10, 2010 | 11:27 PM
blueovalguy's Avatar
Check the pick up coil in the distribator.
Old Mar 16, 2010 | 08:41 AM
bburg03's Avatar
Yes check the pickup at the distributor, check for power, and fuseable link against firewall behind engine. check for good connection. if you need to go farther you'll probably want to start looking at crank and cam sensors. good luck
Old Mar 17, 2010 | 12:42 PM
Thanks for suggestions, we did check the pick up and replaced the distributor, no luck will check the other items thanks again
96f350
Dec 21, 2011 10:14 PM
big haus
Sep 14, 2010 01:24 PM
Fishouttawater
Dec 9, 2008 04:41 PM
motocrazy8
Feb 25, 2008 12:28 PM
