Ticking or Knocking under motor
Old Mar 17, 2013 | 07:17 PM
jsph_wndhm's Avatar
Exclamation Ticking or Knocking under motor
I have a 2006 Ford Freestyle and it just recently began a slight tick or knock underneath the motor beside the catalytic converter. It dont tick when its cold and it doesnt get faster upon giving it gas. The oil does need to be changed but im not quite sure that is the issue.
Old Mar 19, 2013 | 11:52 AM
Use Common Sense's Avatar
If you look, you will probably find the converter(s) heat shield may have broke weld(s). when this occurs, the shield will vibrate against the converter causing a ticking noise. When cold, the shield contracts back against the converter. As the converter heats up, the shield expands away from the converter and starts the vibrate against the converter. Normal fix is either putting a banding kit or the giant hose clamp around it.
rocibecky
Jul 8, 2013 06:16 AM
RandysFT
Sep 25, 2007 08:40 PM
forddriven
May 5, 2006 02:54 PM
dale39
Dec 11, 2005 02:44 PM
cwaire
Dec 16, 2004 08:45 AM
