Trouble starting my F150
Old Aug 24, 2010 | 08:50 PM
ghill's Avatar
Default Trouble starting my F150
I recently bought a well used 1990 F150 and it has a starting problem. I usually have to try several times to get the starter to turn over. At first, I thought it was a problem with the clutch interlock. I replaced the interlock switch and it still has the same problem. I can jump across the starter solenoid and if turns right over. I can also apply battery voltage to the terminal on the side of the solenoid and it starts right up. When I check the voltage that's actually going to the terminal on the side of the solenoid, it only reads 3 volts when the key is turned to the start position. I think it should be 12 volts. When I appy 12 volts it works correctly. Does anyone have any idea why I would have low voltage, only 3 volts, at the solenoid?
84F150351W
Aug 3, 2010 09:22 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
jkmf250
Mar 29, 2007 05:16 PM
AGGIEARCH2007
May 4, 2006 06:11 PM
ab1844
Dec 30, 2005 07:55 PM
