What is the difference between a "shift solenoid," and a "speed sensor?"
Old May 19, 2012 | 12:48 PM
paul4ut's Avatar
Smile What is the difference between a "shift solenoid," and a "speed sensor?"
My Ford: 2001 E-350, Econoline, V10
After a long trip, my van's automatic transmission is shifting rough, revving up before the first shift point.
I ran a diagnostic, and it came back with two codes: one that said check fluid level. I did, and it was ok. The other code said "speed sensor."
When I called the Ford Parts Department at the local dealership, they had a "shift solenoid," but no speed sensor.
A shift solenoid sells for $412. A speen sensor sells (at the local NAPA) for $42.
Anyone have any idea which part I might need?
Thanks
Old May 19, 2012 | 06:54 PM
The best I can try to answer is, the speed sensor provides the info for when to shift , the shift solenoid causes the shift to take place.
The solenoid may be part of a solenoid assy that contains the solenoids.
bwbogott
Jan 23, 2011 03:17 PM
stinkydogfilms
Dec 23, 2007 10:29 PM
mjohnston4314
Jun 29, 2007 10:30 AM
gt_ute_351
May 1, 2004 11:48 PM
