Member Group And Special Buys Vendors and Advertisers will post special group buys for our members here! Check it out.
Reduce exhaust emissions with Eastern Replacement Catalytic Converter
Old Feb 18, 2020 | 07:49 AM
carid's Avatar
Former Sponsor
Default Reduce exhaust emissions with Eastern Replacement Catalytic Converter
The catalytic converter is a key component of the exhaust system. They are built to last and are not exposed to the same levels of wear and tear as moving parts of the car, but a build-up of rust, oil leak, failed gaskets, worn piston rings, or physical damages from rocks and road debris can cause irreparable damage. A faulty catalytic converter will no longer clean up the exhaust gases from harmful carbon dioxide elements, and result in a failed emission test.
Eastern Catalytic is one of the leading suppliers of the rebuilt catalytic converters to aftermarket and OE customers. Each of their products is approved for the use on OBDII equipped vehicles in the U.S. Being made to original equipment (OEM) specifications for a hassle-free installation, it becomes a great cost-effective alternative to OEM parts.
Eastern® - Manifold with Integrated Catalytic Converter
https://www.carid.com/eastern-cataly...converter.html
Eastern® - Direct Fit Catalytic Converter
Eastern® - Universal Fit Catalytic Converter
Read more information about the catalytic converters and reasons why they should be replaced here https://www.carid.com/articles/why-d...onverters.html
Stay on the safe side with replacement catalytic converters by Eastern Catalytic https://www.carid.com/eastern-catalytic/
carid
Mar 17, 2015 07:31 AM
FordMan59
May 10, 2009 06:18 PM
