Air Condition Question
Usually the "low side port" is located on the larger of the two A/C hoses/lines coming from the A/C compressor. It can also be located on the accumulator/dryer as previously stated by Common Sense. Vehicles using the new 134 refrigerant have two different size fittings intentionally so you can't get the fittings on incorrectly. Let us know if you were satisfied with the answers and if they helped you. Thanks, hanky
Typical senario for a vacuum leak in the vent system (most common issue). You will need to check for a vacuum leak under the dash for a loose/cracked/broken vacuum line. Also check the control head wher the vacuum line plug into. Check the vacuum line under the hood that feeds from the vacuum cannister that maintains vacuum when the engine is under load. You could also have a stuck/broken vent door that is stuck in the defrost mode.
