2009 front power windows
Old Feb 10, 2013 | 11:29 PM
JeffN's Avatar
Default 2009 front power windows
Need Advice. My 2009 Ford Expedition (Eddie B) both the front driver & passenger windows are not working. I suspect the lower cables have snapped. Can the cables be replaced, or will the whole window framework need replacing?
Old Feb 11, 2013 | 05:33 PM
way2old's Avatar
If it is the regulator, the entire regulator needs replaced as a unit. Can you hear the motor run when you press the up or down buttons? If not, check the motors first. If you can hear the motor run and nothing happening, the regulator is bad.
Old Feb 12, 2013 | 09:22 AM
JeffN's Avatar
I removed the door panels and see the lower cable snapped (rusted). Motor is fine.
Old Feb 12, 2013 | 05:25 PM
way2old's Avatar
If the cable is snapped, you need a new regulator. You can reuse the motor.
Alex
Dec 4, 2007 06:40 PM
lindenj
Feb 27, 2007 07:14 PM
91EXPLORER
May 31, 2006 11:11 PM
GlenR
Nov 29, 2005 08:28 PM
Van44
Sep 23, 2005 05:57 PM
