hanky |
07-02-2017 02:49 AM |
There is a little more to replacing the battery in your vehicle than we have been accustomed to doing in the past.
If you loosen the wedge clamp nut the wedge should allow the clamp to loosen and be removed from the battery.
These vehicles have what is called the "Battery Monitoring System" and the thought behind the whole idea is good, but can cause problems if you are not familiar with the system. Once the new battery is installed, the computer needs to be told the battery has been replaced or the system will not recognize the new battery and problems develop. You have the option of letting the vehicle sit for 8 hours ,everything off and undisturbed, for the system to adjust or go to someone that has the proper scan tool to communicate with the PCM (computer) and reset the system.
