2012 F150 battery replacement
Old Jul 1, 2017 | 10:55 PM
N48671lwj's Avatar
Default 2012 F150 battery replacement
It is time to replace the battery in my 2012 F150. Is there a trick to removing the cables from the battery posts, or is this a trick by Ford to force purchasing batteries from the dealers?
Old Jul 2, 2017 | 02:49 AM
There is a little more to replacing the battery in your vehicle than we have been accustomed to doing in the past.
If you loosen the wedge clamp nut the wedge should allow the clamp to loosen and be removed from the battery.
These vehicles have what is called the "Battery Monitoring System" and the thought behind the whole idea is good, but can cause problems if you are not familiar with the system. Once the new battery is installed, the computer needs to be told the battery has been replaced or the system will not recognize the new battery and problems develop. You have the option of letting the vehicle sit for 8 hours ,everything off and undisturbed, for the system to adjust or go to someone that has the proper scan tool to communicate with the PCM (computer) and reset the system.
Old Jul 3, 2017 | 03:25 AM
N48671lwj's Avatar
I loosened the wedges and the terminals will turn on the battery posts, but cannot be removed from the posts.
Old Jul 3, 2017 | 10:42 AM
Sometimes with lots of corrosion the wedge won't release and requires a little convincing, also spread the terminal slightly to get enough space to get the terminal off.
Captain B
11
Apr 26, 2023 01:07 PM
guthrie1013@gmail.com
Jun 25, 2020 11:45 AM
makuloco2000
Aug 25, 2014 12:41 PM
makuloco2000
May 2, 2014 10:04 PM
irinadel
Jul 30, 2011 09:46 AM
