2020 explorer sound under dash
Old Apr 24, 2020 | 06:03 PM
dbmdude's Avatar
Angry 2020 explorer sound under dash
I posted this a bit ago in the ford forum but do not recall what happened and it looks like my post is gone.
Brand new 2020 Explorer XLT had a transmission failure + full replacement ~2mon after we bought it
Shortly after getting it back we started noticing a subtle sound from under the drivers side dash. It happens MOSTLY @ ~60 mph but we have heard it once or twice @ 40 mph.
It is intermittent and we all know how warranties do not do a good job at handling intermittent issues. I am hoping someone here has heard it and can tell me how to make it worse so I can go in and get it fixed.
I have more sounds to post if you want them.
Sound Attached
File Type: mp3
Old May 9, 2020 | 06:44 PM
Mitch5929's Avatar
I have the exact same sound underneath my dash , the second month I own my 2020 Ford explore XLT. Took it to the dealership and they resolve the issue in the vehicle. The work order is in the glove box right now, and the vehicle is at the dealership with transmission problems. Will let you know when I get the vehicle back. Purchased January 2020.
Old May 10, 2020 | 01:25 AM
dbmdude's Avatar
Default 2020 explorer sound under dash
Wait your 2020 Explorer has a transmission issue as well? What was the issue might I ask?
Old May 10, 2020 | 07:43 AM
Mitch5929's Avatar
Will not go beyond second gear; manually or in automatic mode. It will go into park and reverse.
Old May 15, 2020 | 01:11 AM
dbmdude's Avatar
Have you got your car back @Mitch5929 ? Have you had a chance to look at your receipts from previous issue that caused sound under dash yet?
Old May 19, 2020 | 07:06 AM
Mitch5929's Avatar
DLR:09497
LIST
1533 0.60 Verify concern, ticking type noise from behind instrument
cluster area when driving above 45 MPH. Check Oasis, no TSBs or SSMs
present at this time. Perform vehicle road test, found noise to a
flutter type noise from front lower exterior of vehicle from wind. Upon
vehicle inspection, found LH side lower vehicle install panel retaining
bolt was not fully secured from assembly. Necessary to secure LH side
lower vehicle install panel retaining bolt (0.30 hours M-time). Perform Test and problem resolved.
Old May 24, 2020 | 11:46 AM
dbmdude's Avatar
THANK YOU @Mitch5929
ganicuss
Oct 16, 2014 05:06 PM
marmar1305
Oct 7, 2010 10:09 AM
marmar1305
Oct 7, 2010 10:01 AM
chul69
Nov 7, 2009 12:21 AM
TexFordOwner
Jun 16, 2005 01:32 PM
