89 351 W with C4 starter problems
Old Dec 27, 2011 | 11:18 AM
1947 mercury's Avatar
Default 89 351 W with C4 starter problems
I am new here and am building a project truck. I have a 47 Mercury with a 351 W and 79 C4 transmission. I put on a new starter and solenoid along with new cables, battery and wanted to make this trouble free. I used the C4 flywheel. When I start the engine the starter hangs up and self destructs before I can remove the battery cable. I have destroyed 3 starters. I changed the flywheel and still same problem. The flywheel is a 157 tooth. I am positive the solenoid is disengaging as I put a hot wire to the dist and pulled the cable from the solenoid when it starts. same thing starter wipes out. These are napa starters and they have warrantyed them. Any ideas?
Thanks
Old Dec 27, 2011 | 06:25 PM
Don't know if this could be the answer. I believe the starter housings for an automatic are different from a stick shift. I think the difference is in the length of the nose (drive end)
dlingner
Sep 26, 2009 11:58 PM
Hbombmike
Sep 16, 2007 11:04 PM
fosterjef
May 6, 2007 06:21 PM
jdm
Feb 26, 2006 08:38 PM
kingtriton351
Nov 17, 2004 12:09 PM
