blower motor
Old Nov 15, 2015 | 10:53 AM
schmidt's Avatar
Default blower motor
I have an 88 f250 xlt lariat with the 302 motor! I just replaced my blower motor and it doesn't want to seem to kick on! fuses good but I can't find my relay for it! any suggestions?!
Old Nov 15, 2015 | 10:48 PM
primem's Avatar
does the blower motor work at any speed?
power should be present from fuse 9 to the orange/brown wire. I suspect this fuse is powered in the run/accessory key setting. Do you have full battery voltage to the blower on this wire with key on?
if yes, jumper the orange/black wire to grd and tell me if the fan runs?
Old Nov 16, 2015 | 02:39 PM
schmidt's Avatar
it does not work at any speed! and the fan is getting power! I had the key in the on position and checked my plug and I believe I was getting 14volts! am I going to disconnect the wire from the fuse box itself?! or what?!
Old Nov 16, 2015 | 05:27 PM
schmidt's Avatar
I tried that! it did not work!
Old Nov 16, 2015 | 08:35 PM
primem's Avatar
if the blower motor is getting power and grd and does not work. the blower motor is nfg.
Old Nov 17, 2015 | 09:14 AM
schmidt's Avatar
how could that be with a brand new motor?!
Old Nov 18, 2015 | 07:05 AM
primem's Avatar
the motor needs 2 things to work; power and grd. you have said that the power supply is present and you were instructed to give it grd. So unless you have done something wrong, the only remaining possibility is a bad blower motor.
how did you provide the grd?
Old Nov 19, 2015 | 02:05 PM
schmidt's Avatar
how the other post told me! from the fuse box!
Old Nov 19, 2015 | 02:08 PM
schmidt's Avatar
Orange brown to ground!
Old Nov 20, 2015 | 07:13 AM
primem's Avatar
and no. onLy thing you should be doing at the fuse box is checking for power.
then check for power at the blower connector ORANGEBROWN WIRE. if that is all good. supply grd for the blower on the ORANGE\BLACK WIRE NOT ORANGE BROWN
apollo
Sep 13, 2009 10:52 PM
SFPD770
Oct 24, 2006 06:28 PM
David Mason
May 27, 2006 08:20 PM
daleh1
Mar 6, 2006 08:46 AM
Deam
Aug 1, 2004 06:20 PM
