Can a Gen3 5.0 V8 Mustang engine fit a 2018 F-150?
Guys someone help me out find an answer ASAP please
Mustang to F150 swap
Originally Posted by htxbryan18
(Post 114128)
You do realize if you have any type problem involving the electronics of your vehicle, no one will want to touch it except Chad if he remembers what he changed.
Originally Posted by jim's brother
(Post 139575)
I just finished swapping a new Mustang crate engine into my 2018 F150. It IS NOT plug and play. I had to change AC compressor, upper radiator hose, different belts. But most of all, the firing and injector order had to be changed in the plug going to the ECU.A total of 24 wires had to be swapped to accommodate the 'Stang firing order. The master tech who made it all work was Chad Browning at Reelsville Auto Services in western Indiana. Cleanest engine swap ever.
Mustang/F150 swap
(Post 139579)
(Post 139970)
Well, since I did all the wiring swapping and it is documented, I don't think I'll have a problem. It was only 24 wires and they were all 5-3, 4-7, 8-2 interchanges to address the 15486372/13726548 timing changes between the two motors.
interesting. Did you have to get a custom tune to do that, change the ECU to a mustang unit, or how did you get that part to work, or did it just work? |
Custom Tune
Originally Posted by mnewbill
(Post 141297)
Hi,
interesting. Did you have to get a custom tune to do that, change the ECU to a mustang unit, or how did you get that part to work, or did it just work? Mine is set up for two levels of performance. An 87 , and a 93 octane as well as stock, if I so desire. Coupled with a cold air intake and a Corsa side exit exhaust, I estimate something just over 500 at the crank. |
Thanks, the reason I asked is in another group someone was doing the same thing, and was told because of the cams being different the ecu would not operate that engine without errors and they said it couldnt be done. maybe your re-wiring took care of that problem they were having.
