HELP! 95 Ford Contour
Old Jul 21, 2008 | 03:11 PM
autonoob's Avatar
Default HELP! 95 Ford Contour
Hi
My name is Danielle and Im havin tons of problems with my car's cooling system. Im new to cars but I'm working hard to understand them and to fix my car so it doesnt overheat after a hour of driving. My uncle is tryin to help me out as much as possible but he doesnt know Fords. I replaced the radator a year ago. replaced many many hoses, thermosat and temp. sensor on the termosat housing. Im now lookin into replacing fuses and the fan but has anyone had this problem? Can anyone help?
Thank you!
Old Jul 28, 2008 | 02:00 PM
edatlmco's Avatar
Default RE: HELP! 95 Ford Contour
You may have a bad head gasket. If your radiator fluid is slowly disappearing or if the radiator fluid is becoming dirty, then you may have a leak in the gasket that is allowing hot gas from the cylinders go into the radiator fluid and causing it to overheat. This is a fairly major and expensive repair.
BigChevy80
Feb 11, 2012 05:09 PM
pokey2001ca
Jul 23, 2009 10:36 PM
soldier730
Jan 8, 2008 02:12 PM
pokey2001ca
Nov 27, 2007 09:21 AM
95se_mexican
Dec 16, 2006 06:52 PM
