Was in a wreck and don't know what to fix
Old Mar 14, 2017 | 09:02 PM
JoshGraham's Avatar
Default Was in a wreck and don't know what to fix
[img]Gallery [/img][img]Gallery [/img]Was hit in the front left on 04 expedition knocked my steering wheel out of alignment and now both front tires are bowed inwards and losing tread on the inside of both tires took it to a shop and they said need to replace rack and pinion,power steering flush,both control arms and both lower ball joints,left otter tie rod end and then an alignment for a grand total of $2,467.96 don't have that kind of money she still drives just tires are going quick lucky I live on base and don't have to drive far does this sound right i have pics just dont know how to post info on posting pics would be nice thank you
Old Mar 15, 2017 | 02:34 PM
Thumbs up
Just below the 'Reply to Thread' box (New Reply) in 'Additional Options' you'll see 'Manage Attachments'. If you click on that tab it should open options to add images off of your device..
How far 'off center' is the steering wheel? Significant sheet metal damage?
Depending on how hard it was hit, hard to know what actually needs replacing. But, when a shop deals in steering or chassis damage most won't cut any corners given their liability is something were to happen. Doesn't mean that repair number is any deal. Nobody likes come backs either.
Loose ball joints, rod ends are common wear points, and probably were in existence prior to it being hit. When being hit, if the steering was thrust or impact forced against its stop it could easily damage a rack/box and even frame issues. Seen quite a few splined shafts twisted like a barber pole..If the steering works fine other than the wheel being off slightly, they may be able to correct with an alignment only. They may/may not be willing to attempt a correction of sorts. If the wheel is well off it's normal clocked position, then a game changer. If the ball joints are slight on the wear/play, as well as tie rod, they could probably still get it to align, but no guarantee as to other concerns, conditional head shake, or unusual tire wear being one or another of them. We used to do quite a few contractors trucks that were,, well, worn in! Get'm close as possible.. If its safe, not safe,, you/they would have to determine..
JoshGraham
Mar 14, 2017 08:59 PM
fsn07
Jun 12, 2013 07:42 AM
picabia
Jul 9, 2009 10:17 PM
itismejoshy
Apr 1, 2007 07:26 PM
stableboy06
Feb 28, 2005 07:23 PM
