Help 1995 2wd ranger won't crank
Old Dec 2, 2015 | 11:34 AM
hillbillywilly's Avatar
Default Help 1995 2wd ranger won't crank
My son's 1995 ranger 3.0 liter 5 speed. Turn key and can hear click a relay. Changed solenoid on fender thinking that was it. With the key on can use a screw driver on solenoid and starts right up. After changing solenoid does same thing. Don't think its the ignition because you can hear it in the relay underhood. Any help would be appreciated
Old Dec 2, 2015 | 02:15 PM
Don't forget the circuit from the ign switch to the starter relay must go through the clutch safety switch. If there is any resistance in the wires or connections it will not allow enough current to fully engage the starter relay. Worth checking !
Old Dec 2, 2015 | 02:17 PM
Ok read about putting a jumper in on CSS to see if thats it. I'll try when i get home. Thank you
zak_exit
Apr 16, 2012 10:23 PM
Godzilla
Feb 2, 2008 09:58 AM
falconfan
Apr 17, 2007 03:23 PM
nicholsmf
Oct 29, 2005 08:03 PM
