engine noise
Old Jul 18, 2017 | 03:32 AM
WS inpearce's Avatar
Default engine noise
Does anyone know how to quiet a'76 FE 390? I'm used to it but would like it a lot quieter. Want to do this with little funds. I can run it without muffler and sound hardly changes.
Old Jul 18, 2017 | 11:31 AM
Those old cast exhaust manifolds like to crack and split, exhaust donuts leaked, exhaust manifold gaskets blow out, pipes/flanges rot out. If running without a muff isn't a lot louder, I'd be guessing you have some substantial exhaust leaks.
If you can better pin point any leak areas, would be easeier to make suggestions.
Old Jul 18, 2017 | 12:38 PM
As far as I know there are no leaks and I have long tube headers on. I was convinced it would give me more power, turns out I just needed to tweek the fuel and ignition a little. I did however found header was cracked at collector and welded it and did not really make a differance. And no leaks that I know of. 3" exh in and 2 2.5" tailpipes. was that way when I got it. little to no rust on entire exhaust.
rpalm
Mar 4, 2011 04:20 PM
393c stroker
Dec 2, 2006 01:23 AM
mccall33
Oct 4, 2005 04:43 PM
Michele
Oct 3, 2005 06:32 PM
cctxfish
May 7, 2005 06:04 PM
