South West AZ, TX, NM, OK
2016 Ford Focus dash lights go out after pressing the operation button.
Old Jul 15, 2022 | 05:19 PM
MasterTron's Avatar
Default 2016 Ford Focus dash lights go out after pressing the operation button.
Just recently I have had my car suddenly stall for no apparent reason, then the display shows 'Startup system failure" and the car refuses to start, but I did notice when I pressed the operation button on the gear select all the dash lights go out, including the computer display, the same when I press on the brake pedal, and also when I turn on the wipers, does this mean the battery is totally fudged? If so, and I get a new battery, are there any procedures that need to be taken when fitting the new battery? Such as, reprogramming the fob, resetting the computer, etc etc.
Old Jul 15, 2022 | 05:50 PM
Depending on where you purchase the replacement battery, they come with the necessary info to enter into the vehicle's computer notifying it the battery has been changed,
If the computer has compensated for the old battery with a special charge output and now the new battery doesn't require that charge output it can ruin the new battery by overcharging it.
Battery replacement is not as simple as it once was.
katzman2
Mar 24, 2020 11:11 AM
Leerm79
Dec 27, 2018 12:25 PM
Noel Santoro
Dec 28, 2016 10:25 AM
AdrianTC
Dec 25, 2016 04:07 PM
Kyle44
Nov 11, 2010 05:44 PM
