Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Gateway Performance Suspension
Old Jul 30, 2010 | 04:32 PM
roadracemustang's Avatar
Default Gateway Performance Suspension
Hi All,
I just installed this new suspension and steering setup from Gateway Performance Suspension. It is a Coil Over Strut conversion kit that eliminates the factory upper control arm, coil spring, shock, and factory spindle. It would take way too much typing to list all the details. All I can say is it was the easiest kit that I've ever installed. They have a bunch of front kits to choose from depending on what size brakes and the amount of adjustability you need. They also have power rack & pinion steering kits, a totally kick a!! rear 3-link setup, and some other supportting items.
There kits fit most of the vintage fords from the early 60s to the mid 70s. Check them out here: www.gatewayperformancesuspension.com
coolt2190
Nov 4, 2008 02:44 AM
3.0_liter_02
Jan 20, 2006 12:02 PM
superdookie1
Apr 7, 2005 02:42 PM
FordZX2
Sep 4, 2004 10:30 PM
new era performance
Jul 14, 2004 07:00 PM
