5R55W No 2nd No Overdrive
Old Sep 15, 2023 | 03:32 PM
mattsal's Avatar
Default 5R55W No 2nd No Overdrive
R55W Transmission Showing P0775, P0732, P0735
2004 Lincoln Aviator V8
Following information on the net, I have replaced the "coil pack" inside and also replaced the 2 servo pistons from outside. Problem persists, My son said he was getting off the highway and herd a clunk, overdrive light and check engine light came on. New filter and fluid at the time of the coil pack. Transmission shifts from 1st at high rpm, skips 2nd and goes to 3rd, 3rd to 4th is fine, no overdrive. Any ideas???
Thanks in advance
Old Sep 16, 2023 | 06:49 AM
Sometimes the retaining ring will come out that keeps the OD piston in place. Check for that.
If you still have the same problem after replacing solenoid parts, that would tell us an incomplete diagnosis was done and now you need to look for the real problem which could be something like a poor electrical connection.
dechler
Oct 28, 2011 10:43 PM
tonymac14
Feb 13, 2009 03:14 PM
monkeyman295
Sep 9, 2008 11:50 PM
countrysquire77
Aug 15, 2007 07:55 PM
Tom Schlichting
May 9, 2007 08:02 AM
