C-4 Transmission
Old May 25, 2024 | 01:08 PM
HappyPappy08's Avatar
Default C-4 Transmission
I have a 65 Galaxie with a 289 and a C-4 transmission. The car will not go into park or 1st gear. If there is any pressure on the tires it won’t go into any gears. I’ve checked all the linkages and see nothing wrong. Please help
Old May 25, 2024 | 02:32 PM
You will need to drop the trans pan and look at the link that moves a spool valve. That link is what you move when you select gear positions.
You cannot tell what is wrong inside until you look there.Let us know when you have the pan off.
You might get a filter and gasket kit so after you correct the problem you won't have to go back in there later.
bdk5
Aug 19, 2019 11:57 AM
Jtone
Sep 6, 2017 10:34 AM
Ford_ranger
Jul 28, 2015 08:40 AM
Bow_Tied
Apr 25, 2011 09:51 PM
nickflorent
Jan 11, 2010 10:22 PM
