C6 4x4 conversion
Old Jan 27, 2020 | 11:38 AM
79f2507.3's Avatar
Default C6 4x4 conversion
Need help from someone with extensive knowledge, and before I go further let me say this. No I’m not selling the truck and buying a 4x4. I have tried to locate a c6 4x4 trans for a while but being it’s for the 6.9/7.3 it is not an easy task. The truck is pristine I have all the abilities to do the swap minus the knowledge of the shafts
with that said I have a 87 f250 that came with a 6.9 but I just threw in a brand new reviva rebuilt 7.3, it is the ext can long bed 2wd, I’m moving someone a bit remote and 2wd is not gana cut it. I have a parts truck with everything I need for the 4x4 swap but it’s a gasser. I will be swapping the output shaft and tail housing to convert it to 4x4.
I need help in figuring out what size output shaft I need. If anyone has good knowledge and can just let me know what length I need that would be splendid unless someone has a 4x4 c6 diesel trans laying around
helpford
Dec 5, 2008 10:40 PM
bronco2
Sep 22, 2006 08:22 AM
bronco2
Sep 16, 2006 06:57 AM
beanfletcher
May 27, 2006 12:48 PM
alty79
Dec 12, 2005 11:19 AM
