93 Ford Aerostar 3.0L RWD
Old Dec 17, 2009 | 02:18 PM
ahstanford's Avatar
Default 93 Ford Aerostar 3.0L RWD
Hello everyone,
I recently purchased a 1993 Ford Aerostar 3.0L.
I have a vacuum hose coming from the positive crank case ventilation valve, but the other end is not attached to anything. I'm hoping someone here can either identify where this hose belongs and/or provide me with the vacuum hose diagram.
Also, the transmission on this vehicle shifts smooth through first, second and third gear but will never shift into overdrive. If I let off of the gas at high speeds in the overdrive position, the van just freewheels.
The speedometer on the vehicle has not worked since it was purchased. The ABS light on the dash stays on. I was told by the Ford dealership to replace the sensor on the rear-end - after buying it from AutoZone and trying to replace it - it did not repair the speedometer or ABS issues.
Any help would be highly appreciated.
Thanks in advance,
Alex
Sanddoc
Sep 6, 2014 08:21 PM
injectedf150
Jan 11, 2012 02:32 PM
ZVNJ
Jun 22, 2010 10:05 AM
klbird
Jul 7, 2009 05:33 AM
zerocygnal
Oct 16, 2007 08:00 PM
